The Fightstick R10 Pro: Plug and Play with Recalbox!
Tue Jul 07 2026
While 10.0.8 focused on optimizing graphics memory—making the 2 GB Raspberry Pi 5 just as capable as the 4 GB model—that's not all it brings. Arcade and fighting game fans, in particular, are in for a treat. The Fightstick R10 Pro (as well as the R9) is now officially supported by Recalbox, with automatic configuration based on the game you're playing.
Compatibility designed for arcade gaming
The Fightstick R10 Pro, along with the R9 and its built-in spinner and trackball, joins the list of controllers officially supported by Recalbox. This support is aimed primarily at fans of fighting games and classic arcade titles, where a dedicated arcade stick makes all the difference in terms of precision and authentic gameplay.
Fully automatic configuration
No button mapping to tweak, no profiles to load manually: Recalbox automatically detects the stick and adjusts its configuration to match the game you're launching. It's exactly the plug-and-play experience we want to provide, letting you jump straight into the action without unnecessary setup.
Available now
This feature is included in the latest version of Recalbox (10.0.8). If you own a Fightstick R10 Pro or R9, simply plug it in and start playing—no additional configuration required.
A few more improvements for everyone
If you've already read the 10.0.8 release notes, none of this will come as a surprise. Still, here's a reminder of some of the other notable improvements included in this update:
  • Added a check for available disk space before starting an update, with a pop-up warning.
  • Fixed read/write performance on the SHARE (exFAT) partition.
  • Fixed GPICase HDMI output and the default button mapping.
  • Fixed a bug that caused an endless reboot loop with the default theme in Tate 4:3 HD mode.
  • Fixed OLED display support for RGB JAMMA.
  • Fixed reversed button 6 mapping on JAMMA 2.
If you'd like to dive deeper into everything included in this update, check out the full release notes.
Happy upgrading!
Image: Smallcab
Fightstick R10 Pro
Commenti
Ancora nessun commento.
